Shock Tower braces
Discussion in 'Technical' started by fomoco74mavgrab, Feb 6, 2013.
  1. fomoco74mavgrab
    fomoco74mavgrab Member
    wi
    74 mav
    Has anyone ever found that not having shock tower braces causes any problems. I can not fit mine in any longer and didn't know how much effort I should put into strengthening the front end. Running about 240 hp.
  2. Dave B
    The front shock towers can shift without them, these cars can be pretty soft, so you'd be better off trying to get them back on.
  3. fomoco74mavgrab
    wi
    74 mav
    Maybe I'll try making a complete over-engine type bar like the modern riceburners and tie it into the firewall somehow.
  4. 71gold
    may want to find out why your shock towers are collapsing...:yup:
  5. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    I wonder how far they are from fitting back on. It could be the frame that is mounted to the floor pans.
  6. darren
    DO they not fit due to the engine or due to the towers moving in? You can just spread the towers and install the factory braces if that is your issue.
  7. fomoco74mavgrab
    wi
    74 mav
  8. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    Can you do something like this?
  9. scooper77515
    This setup may be for sale soon...after I cut out my shock towers, and slap in an MII setup.
  10. fomoco74mavgrab
    wi
    74 mav
    I guess I'm gonna have to get creative. The ones to the firewall will need to be curved to wrap around all my intake and inter cooler piping. And again on the front of the engine the piping will still get in the way.
    I bet the first time I have to change spark plugs ill hate myself for the torture. It'll take 3 hrs ripping all this crap off.
    I found a guy on eBay who custom makes these out of stainless.... But I'm guessing there will be trial and lots of error.
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    May be best to avoid the heim joints too even though they look so pretty and allow slight adjustments. Biggest problem is that they also allow slight movement which defeats some of the bars intended purpose in the first place.
  12. olerodder
    olerodder Member
    NorCal
    Well, I use them on my shock tower braces, my ladder bars, front strut rods..................and they use them most all race cars............don't see how they can allow slight movement as long as they are installed correctly with the correct hardware. If they use them on F1/NASCAR they are good enough for me.......................IMHO
  13. groberts101
    groberts101 Member
    Minneapolis, MN
    Of course they have their uses and I can only tell you what others who build monte carlo bars and tower braces have said and tested on these unibody cars.
    Shock towers dont just want to flex towards the firewall.. they want to flex up and down as well. Heim joints will allow that kind of flexing without much restriction.
  14. scooper77515
    Mine don't flex or move at all.
    When I installed them, I cranked them to where they are putting a slight pressure outwards. Not enough to move the metal, but enough to take all the slack out of the joints.
    I could REALLY feel the stiff difference immediately after installing them.
  15. rthomas771
    Heim joints are made to move...it's in their design. You may not see the movement but they are moving up and down. The reason you could feel the difference is because something is better than nothing. The factory tower braces have slotted and over-sized holes and will fit even if things got tweaked out of shape. If you don't believe me then loosen all the nuts and bolts and wiggle the brace. I modified a Mustang export brace to fit my Maverick and it really made a big difference over the factory setup. I want to make a Monte Carlo bar to fit my six cylinder but it will have to be a 2nd choice in design instead because it won’t be a straight bar. I’m thinking about a H-beam design similar to what is on the late model cars if I have the hood clearance
