Shock tower ??
Discussion in 'General Maverick/Comet' started by Dsnell1004, Feb 16, 2014.
  1. Dsnell1004
    Dsnell1004 Member
    Corpus Christi texas
    1971 maverick grabber
    Why would my shock towers have a worn through hole in them on both sides. It looks like the control arm bolts rubbed through. Is this common?
  2. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    I assume they are on the front and back of the tower. People would commonly cut holes in each side so they could easily install zerk fittings and grease the control arm bushings.
  3. 71gold
    most I've seen were blown out with a torch...really blown out...:yup:
  4. Moneymaker 1
    Panama City Florida
    Looks were not as important as shutting up that squeaking noise back then!
  5. 71gold
    I wish I had taken pics. of all the ones I've seen. of all of them, I think Jeff's were the biggest...he had a pic. posted once.
  6. mav1970
    Back when I still had my towers, I tried to guess where the zerks were and put a hole saw through the tower, didn't get it centered, and then got the round files out. I had a big egg shaped hole before I could get the entire tip of the grease gun in there :biglaugh:
  7. 71gold
    mine were already cut...I took a...washer that was 7/8" ID and 2" OD...and welded it over the hole, then molded it in. got a rubber plug and popped it into the hole. it looked...store bought...:thumbs2:
  8. rthomas771
    Here is the whole hole thread on my shock tower http://mmb.maverick.to/showthread.php?t=44292
