shorty headers vs longtube headers
Discussion in 'Technical' started by RUBEN, Jan 5, 2011.
  1. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    Im thinking about buying some headers for my mav but im stuck on buying the longtube hookers or the shorty hedman 88400. I want to know if any will effect the power and which one is better for street use.
  2. bmcdaniel
    In a nutshell, the shorties are easier to install but long tubes will have better low- and mid-range torque.
  3. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    do the shorties have any hp or torque increase
  4. maverick75
    In theory yes, but no one has dyno`d them. So no one has any idea of how much HP/TQ. Anything is better than the stock crappy manifolds though....
  5. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    ok thanks I think i will buy the shorties then
  6. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I got shorties because people were saying the long tubes had ground clearance problems.
  7. john T
    john T Member
    coalinga CA
    72 maverick grabber
    dont forget long tubes wont work with a column shifter
  8. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    mine is column shift. is heard there was a fitment problem with the shorties though. is that true?
  9. drag460
    drag460 T-Shirt guy
    El Paso, TX
    the hedman shorties work w the column shifter
  10. RUBEN
    RUBEN Member
    Pala, CA
    1976 Ford Maverick
    :) ok thanks
  11. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Short tubes, in theory, are good for high rpm operation, while long tubes bring the power band down lower in the rpm range. However, that can be offset by the fact that most long tube headers for our cars use 1 5/8" tubes, and sometimes 1 3/4" tubes. I don't know about the specific shorty you are looking at, but many of them are 1 1/2" primary tubes, which will artificially keep up port velocity by restricting the exhaust.
    The LTs are going to make the broadest power, but the shorties are going to be better than manifolds.
