Shouldn't my engine Rev higher?
Discussion in 'Technical' started by ESampson, Nov 14, 2014.
  1. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    Well it's a Decent little 347 with 180cc RHS heads, 650DP (switching to a 750 next season to see if i pickup any ET) Performer rpm intake, msd ignition/dizzy. The cam is a XE294 which is a 2800-7000 powerband Duration @ 50 is 250 intake and 256 exhaust valve lift .554 & .558 lobe lift 347 & 349 with 110* lobe speration. i have all the matching parts that go along with the cam, what would cause my car to fall flat at 6400ish and start to get valve float? shouldn't i be able to take this thing past 7000, even if the power starts to drop off?
  2. aussie maverick
    aussie maverick Member
    queensland australia
    1973 maverick ex ed davis
    I have a similar set up to this, using a stage4 trickflow with 592 lift. 3000-7000rpm range. This cam was designed for 5.0 so in saying that you can take off a couple of hundred revs(compensating for the longer stroke). Mine was falling over at 6400.....until I dyno'd it and found out my taco was 1000rpm out! Oops... Power curve peeked at 5800 and stayed level through to 6700
  3. Bryant
    the larger displacement of the stroker kit will move the same amount of air as a 302 at a lower rpm. the cam and intake advertised rpm band is based on a 302. so a 347 will run out at a lower rpm.
    i dont know if it will fall off 600 rpm earlier but it is a factor. were the valve springs installed heights verified for the cams requirements?
  4. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    they were ordered as a matching package from compcams, i only checked part #'s once it arrived, then i went ahead and just put it all together.
  5. aussie maverick
    When you say you just put it together, I assume that you did dial the cam in? The 5.0 cam won't have a difference of 600rpm
  6. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    I had the shortblock assembled at a shop because of the stroker kit, rods only came semi-finnished ect. i put the heads together for this one..the last one that blew up, i put together lol. if they didnt "dial in" the cam, could this cause it?
  7. aussie maverick
    It could, and probably would, but if it was a reputable machine shop, I'm sure they would have dialled it. It may still pay to ask them.
  8. ESampson
    ESampson Member
    Nanaimo, BC
    1974 Comet GT
    i went to my box of recipts and checked to see what they charged me for...nothing on it about degree'ing the cam...so could this really be the issue? the last thing i want to do it pull my motor and degree it....i'd assume if they didn't degree it, it would be installed "straight up"
  9. Bryant
    just because the springs were recommended for the cam doesnt mean you can just install them. you need to check the installed height on the heads.
    it could be the cam not being degreed properly or not enough spring pressure to get past that rpm. i would expect the cam being in wrong would not limit the rpm it can rev to. the valve springs not being installed at the correct height can easily lead to valve float and that will limit rpm.
  10. 71gold
    I would look at the valve springs...(valves floating).
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    The simple fact of life is that cubic inches ALWAYS eats up cam duration. Put that same cam in a 427 windsor and watch another 4oo rpm fall off the top.
    Things that can work against you for extending power past peak rpm.
    1. Too much ignition lead can easily make a motor fall over faster past peak power.
    2. Not enough air flow for the cubic inches/rpm. Slightly smaller than required carb, dual plane intake, and wrong air filter base combined with too short/restrictive of a filter element.
    3. Not enough exhaust flow for the cubic inches/rpm. Street style headers with small'ish primaries/collector size along with chambered mufflers(INCLUDING unpacked mufflers like flowmasters) and/or too long of a collector/too many bends/too small a pipe all add up to snuffing out a top end in short order.
    4. Unported 180's are marginal for the rpm's you're shooting for here. 200+ cc heads would be best and porting those heads would give you power everywhere. Especially up top on a stroker motor. Conservative estimate would be in the range of about 25 horse.
    5. If you have steel retainers?.. move to titanium ASAP. Same springs with Ti retainers will feel like you upgraded the springs with another 200-300 rpm for the money spent. Heavy(large diameter) springs and steel retainers can lead to spring surge well before valve float sets in. Surge will kill rpm without giving you the tell tale signs that float will. Kills springs faster too.
    My suggestions. Take some total timing lead out(those RHS's chamber shouldn't need much more than about 38 total and you might even try 36 to see if you gain anything on top. Uncork the exhaust. Take off the air cleaner.
  12. 71gold
    would any of this...float the valves...:huh:
  13. 71gold
  14. groberts101
    groberts101 Member
    Minneapolis, MN
    I thought that #5 above clarified potential problems but how did we come to the final conclusion that he's floating them?
    It could be a little bit of.. all of the above.
  15. stroker mav
    stroker mav Member
    canton, ohio
    1964 country sedan,1933 essex terraplane
    what was your et and mph with that combo?
