side mirror removel???
Discussion in 'Technical' started by 351cMAV, Oct 27, 2003.
  1. 351cMAV
    351cMAV Member
    Canada
    76 Maverick 2dr
    Well i just cant seem to figure out how to remove my side mirrors. I.ve tried but maybe im just missing something....or i got a bad case of the blondes
    :confused:
    advice would be nice thanks
  2. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    What exactly is the problem? If it the screws being stubborn, that's a common problem. They have a tendancy to rust in the threaded ends in the doors. Try a real good penetrating oil such as Kroil or PB Blaster. If you get inside the doors, you stand a better chance of reaching the threads from underneath. Let it sit a good while and try again, being careful to use a good Phillips driver as not to strip the heads. If you have an impact driver, you might want to try that after the screws have had ample chance to soak in the penetrating oil.
  3. Craig Selvey
    Sometimes the "nut" on the back side just spins making it impossible to get off from the outside. Take off the door panel and put a small pair of vice grips on the nut. It will spin until the vice grips hit an object that will then hold it in place.
    Only use an offset screwdriver when removing these mirrors.
