Six-banger help
Discussion in 'Technical' started by Hawkco, Apr 22, 2004.
  1. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    A gentleman is looking at buying a 250 ci I have. He wants to put it in a 1964 Econoline (Van). It currently has a 144 ci with a 3-speed manual. The 144 has a 4-bolt bellhousing. Of course the 250, has a 6-bolt. He knows he will need a new bellhousing and clutch, however are there any issues on the linkage with his current setup that would prevent him using a 250 engine? If not, what bellhousings will work for him? anybody have a clue?
    Thanks,
    :confused: :confused: :confused: :confused: :confused:
  2. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    that 250 will prolly grind that little tranny to bits so he will want to get a better tranny too ;)
  3. Mavaholic
    The 250 and 302 use the same bell housing. Clutch linkage should be the same. I had one of those Econolines many moons ago. It was a pretty neat van but it is a pretty wimpy transmission. First gear is also unsynchronized. I dont have a clue wether it has the same bolt pattern as the newer 3 speeds. I'd go ahead and get a newer one. That way it will bolt up to the bell housing, be alot stronger, and fully synchronized. THey should be pretty easy to come by.
  4. MustangSix
    MustangSix www.fordsix.com
    Try http://www.inlinepages.com/ for a ton of inline six transmission/bellhousing info.
    The little non-synchro three speed won't bolt to any 250 bellhousing.
  5. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    f.y.i. those econoline vans have 9" rears.
    I found that's what my Maverick has in it when I went to get new brakes for it.
