so - 75 -76 -77 rear drums are the same -<75 earlier differ - so
Discussion in 'Parts Interchange' started by nobler, Aug 27, 2014.
  1. nobler
    nobler Member
    london
    1932 ford pick up
    what other model - I am searching in the uk
    uses a
    10 inch drum
    2'' friction surface 'although it is only 1.75 - it uses the wider drum
    BUT has the 2.75 inch register / spigot rather than the 2.5''
    thanks
    -yes I have just bought an incorrect pair, must be 67 mustang as 2.5 register
    1.75 narrow
    bugger
  2. mercgt73
    What year vehicle are you looking for exactly?
  3. krelboyne
    krelboyne Remember
    Salem, Oregon
    I think that sometime 1971-74 they changed the center hub diameter.
    10 x 2 inch drums fit a bunch of different Fords, check center hub diameter, and for the 5 on 4-1/2 inch lug pattern.
