SOS Proportioning Valve Needed
Discussion in 'Parts Interchange' started by Mr Nick, Aug 22, 2014.
  1. Mr Nick
    Mr Nick One with many questions
    Grapevine, Texas
    1971 Four-Door Maverick, 1962 Cadillac Sedan deVille (soon)
    Hello all,
    I am in need of a proportioning valve for a front disc/rear drum setup with '74 comet brakes in the front and a '71 Maverick rear brake setup. Are there any aftermarket/interchangeable/universal valves I can use?
    Also, does anyone know where I can get the big axle (hub?) bearings for a '71 Maverick setup and what would work?
    Also, and here's a long shot, but I need '74 spindles as well. They're in semi-rough shape and I would like a nicer set just in case.
    Thanks,
    Nick
  2. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    I have the proportioning valve
  3. Mr Nick
    Grapevine, Texas
    How much?
  4. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    15 bucks you pay shipping
  5. Mr Nick
    Grapevine, Texas
    You got it, Let me know how much shipping is tomorrow. Do you want to do a money wire through walmart or by mail? However you want to do it is fine.
  6. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    I will dig it out sunday. a USPS money order is best. I need a zip to figure the shipping
  7. Mr Nick
    Grapevine, Texas
    76051
  8. 71gold
    is this a proportioning valve...or the distribution block ...you need?
  9. Mr Nick
    Grapevine, Texas
    I was told I need the valve. What's the difference? :huh:
  10. Dave B
    I put disc's on the front of my 73, close to six years ago, I left the factory drum/drum distribution block in place, my brakes work just fine, but I did replace the master cylinder with a 74 disc/drum master.
  11. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    ford used many different valves but I have no idea what difference is internally other than the spring. part of the function of this valve is to sense a pressure loss to either the front or back and move the spool valve to block flow to that low pressure side. drum/drum master cylinders verses disc/drum master cylinders should only have residual pressure valve(s) on the drum sides. disc calipers need the slightest amount of fluid to return with the caliper piston for brake release where drum set ups have springs to retract the shoes upon release. I have heard guys on this site say they have used standard drum/drum master cylinders after converting to front disc and I have heard guys say they change master cylinders to a disc/drum master cylinder as part of the conversion. PERSONALLY I am going to change the master cylinder during my conversion as that is where the bore size change and residual pressure valves are located. I am most of the way through my conversion but not finished and have not driven it yet.
  12. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    also interesting to note I saved the "valve" off a 1970 I had and converted to disc and there was no safety spool it was just a distribution block. That car I pulled the donor cars master cylinder and valve off and used for the conversion. For myself I generally use factory engineered parts and systems figuring there was a reason they spent the additional money to build it that way...........
  13. Mr Nick
    Grapevine, Texas
    So from what I'm gathering a new master cylinder ('73-'74 era) would be the wisest choice and most cost effective choice
  14. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    Thats my opinion and rockauto would also be my choice although summit has been very competive with rocks prices on alot of items I purchased recently
  15. Mr Nick
    Grapevine, Texas
    Good to know. I've been back and forth between Rock and Summit recently as well.
