spare tire
Discussion in 'Wheels and Tires' started by 73curtis, Mar 9, 2015.
  1. 73curtis
    73curtis Member
    ohio
    I have discs on the front drums in the rear with 15x4.5 5 spoke aluminum wheels, I don't have a spare, what size wheel and tire would be best to fit in the trunk,was the original size 14x6?
  2. 73curtis
    73curtis Member
    ohio
    does anyone know the original back spacing, or what would work
  3. Dave B
    You'll need a wheel from a 74 & up, so the center bore will clear the hub on the disc brakes. Just find something that is close to the diameter of what you are running.
  4. 73curtis
    73curtis Member
    ohio
    would those years be 14 or 15s
  5. 71gold
    if you have any type of locking rear end you need a tire the same diameter as the rear tires...:yup:
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The original would have been a 14x 4.5".
    My current spare is from a '75-'80 Granada, which I think it s 5 or 6-inch wheel.
    The tire size is 195/75-14.
  7. 73curtis
    73curtis Member
    ohio
    no locker,just stock 8 in.with 6cyl. I was just going to call a salvage yard for a wheel but I wasn't sure what to ask for, I guess 14 or 15 in for a 74 and up would that be right.
  8. 73curtis
    73curtis Member
    ohio
    thanks , thats what i will try and find then
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Not to hijack this thread, but this raises a question for me. Would a difference of only .16" cause a problem with a limited-slip (Traction-Lok) rear-end??
  10. 73curtis
    73curtis Member
    ohio
    I doubt it I used to race circle track cars and we had locker units in them with 3 inches of stagger and that worked good locked during acceleration and unlocked in the corners
  11. 71gold
    was that on dirt?
  12. 71gold
    how did you measure a .16" difference...:slap:
  13. 73curtis
    73curtis Member
    ohio
    asphalt
  14. 73curtis
    73curtis Member
    ohio
    do you know what the back spacing should be?
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No, but it's pretty irrelevant on a wheel and tire that narrow.
