Spark Plug Wires ... Which one goes where?
Discussion in 'Technical' started by dmhines, Jul 6, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
  2. Mercurycruizers
    Venetia, PA
    I custom made mine with Taylor Blue wires......Gotta love the neat & clean look....
  3. 71gold
    "dan da man" (y) thanks
    ...frank...:bouncy:
  4. dmhines
    Cumming, GA
    I'm thinking about putting Accel 300+ Racing wires on the Grabber .... Black with Red spark plug connectors just like factory ... Dude on eBay has universal sets for 1/2 of what Summit and Jegs gets for them .... A Boss 302 message board recommends them for both performance and appearance ... He's all out of the 302 Custom fits so universal is the only option for $40 ....
  5. courier11sec
    courier11sec Member
    Tucson, AZ
    neat! Bookmarked.
  6. Dan Greenbaum
    Dan Greenbaum Member
    1977 Maverick
    nice! I like this better than laying the wires out on the driveway and guessing. It took me much longer than i expected to get the wires to look nice. All the wire swithing could have been avoided with this info. Thanks!
  7. don graham
    sounds like a good deal to me.:)
  8. dmhines
    Cumming, GA
  9. Mavaholic
    Every set of custom premade wires I ever bought always looked like crap anyway. Only way to make it look really neat is to cut them to length yourself, after your timming is set.
  10. Gert Sanders
    Gert Sanders El Torro Caminando
    Belgium
    1974 Mexican Built Maverick
    excellent resource, thanks Dan !
  11. Russ
    Russ Found On Russ's Drive
    New Brighton PA
    74 "Bruiser" Mav-
    I always wondered if the spark plug wires should be the same length. I know it is minute, but the current still has to flow differant distance to the plugs that are father away for the distributor. In all out perfection shouldn't the distace be the same? Timing would be slightly retarted at the cylinders at the other end of the engine. I know in my fuel injected diesel truck the injector line are all made the same length so the fuel gets to the injectors at the same time. (relitive to piston location). If the wires were kept the same lenght it would take the same amount of time to get to each plug.
    OR maybe I'm just thinking too much.:huh:
  12. Mavaholic
    Your thinking too much. :D The difference could probably only be seen with a high dollar ocilliscope set at the shortest time setting. Well below micro seconds probably.
  13. dmhines
    Cumming, GA
    I'm pretty sure electricity flows just slightly slower than the speed of light ... shouldn't be an issue going either 20 inches for 30 inches ... :)
  14. NICK DOMINICK
    Burke, Virginia
    So there is a difference!!!
  15. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I usually ground the #4 plug wire to my shifter. Makes the cam sound more choppy and urges me to shift quicker!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
