Spark plugs
Discussion in 'Technical' started by Smitty, Mar 5, 2018.
  1. Smitty
    Smitty Member
    Keller, Texas
    1974 Ford Maverick Grabber
    Anyone have edelbrock heads on their 302? If so what plugs do you run, mine had champion Rc12yc in them.
  2. Krazy Comet
    I've run those but like the Autolite 3924 for street and 3923 for racing... I have Trick Flow Twisted Wedges but almost all aftermarket heads use same plugs...
  3. Hotrock
    Munroe Falls, Ohio
    I also run Autolite 3924s for all occasions in my AFR headed 302. I use a dab of anti seize on each plug.
  4. Smitty
    Smitty Member
    Keller, Texas
    Thanks for your input!
  5. Smitty
    Smitty Member
    Keller, Texas
    Thanks! I’m going to give the auto lite 3924 a try
  6. Acornridgeman
    Wisconsin
    Champion RC12YC is the cross reference to an Autolite 3924 ............ :)
  7. mojo
    I use anti seize on my plugs too... and on many other bolts/threads where I think will make life easier, if/when I need to remove them.
    71gold and Hotrock like this.
  8. Smitty
    Smitty Member
    Keller, Texas
    Engine before updates
  9. Smitty
    Smitty Member
    Keller, Texas
  10. bmcdaniel
    I always ran Autolites in my Ebrock heads until last year. Bought a new set of Autolites because I need to run double platinum plugs with my EDIS ignition. Four of the plugs kept coming loose, the threads were undersized. Threw the boxes away before I checked where they were manufactured. Guys on SpeedTalk recommended NGKs made in Japan. They are some really nice plugs
  11. 72MAVGRABHER
    Roanoke, Va.
    I have Edelbrock performer rpm heads and switched to E3 plugs and never looked back. Almost 7yrs now still not fouled
  12. 71gold
    I've been wanting to run some E3s but haven't read enough feedback info. yet.
  13. 72MAVGRABHER
    Roanoke, Va.
    I’m telling you, no gapping tri fire, they’ve been in the 347 for 10k miles and about 7yrs through thick and thin and it starts easier/quicker (assuming fuel pump has carried fuel to bowl) it was around $55 back then to buy 8 which I complained about lmao but it’s been an out of sight out of mind thing until I saw this thread haha
    71gold likes this.
  14. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Are you talking the E3 Copper E3.42 plugs?
