spectra f30 '77 maverick fuel tank in a '73
Discussion in 'Technical' started by Flinn, Aug 6, 2015.
  1. Flinn
    Flinn Flinn
    Idaho
    73 Maverick
    Need a new tank for my 73 has anyone put one of these in or have a good clean one for a 73 for sale? What is required to fit spectra?
  2. rthomas771
    You will need longer strap bolts and newer vapor valve with grommet.
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I just finished doing this in a 72 Comet. I used the straps and sending unit from a 75 Maverick. I have the original 72 tank and sending unit, but the tank needs to be vatted.
  4. Flinn
    Flinn Flinn
    Idaho
    73 Maverick
    If I put in the 77 tank should I run the 77 sending unit people sell so it reads level correctly? New vapor valve and grommet? Tank looks the same as my 73 tank just deeper by about 2". Also will my 73 filler neck fit in this tank?
  5. 71gold
    I have gotten some from late model gas tanks at the JY...:thumbs2:
    ...also known as a...roll over valve...:yup:
  6. ArthurDavis
    ArthurDavis Member
    1973 Ford Maverick
    I just wanted to verify before I started buying parts. I just pulled the gas tank off of my 1973 Ford Maverick. It definitely needs to be replaced. I'm just looking for verification that these are the parts that I'm going to need and that everything is going to function properly.
    Gas Tank Spectra F30: http://frugalmechanic.com/auto-part...ull#s=bing&m=cpc&c=spectra&t=spif30 fuel tank
    The 1976 fuel sending unit: http://www.ebay.com/itm/like/221956884846?item=221956884846&lgeo=1&vectorid=229466&rmvSB=true
    The 1977 vapor valve: http://autokrafters.com/Ford-Maverick-1977_p-2836-fuel-vapor-valve-71-77-maverick-comet.aspx
    and the vapor valve grommet: http://autokrafters.com/Ford-Bronco-1984_p-6952-fuel-vapor-valve-grommet-71-77-maverick-comet.aspx
    Thanks.
  7. jasonwthompson
    Carrollton TX
    I do not remember if the tank came with the fuel neck grommet or not. However you may also want to get the gasket for the fuel neck to the tail light panel and the seal that the fuel neck passes through that screws to the trunk floor as well.
    ArthurDavis likes this.
  8. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    I replaced the tank on my 72 Comet with the spectra F30 tank. Used a new grommet and vapor valve. used the longer straps. I have dual exhaust and the tail pipe ran close to the fuel line and sender which is also for the F30 tank. I used header wrap on my pipe on the drivers side. don't know if it was necessary or not just didn't want to take any chances. My Comet has 2 3/4" tail pipes.
  9. 71gold
    I got a used V.V. and grommet from a late model tank ('02Linc. I think)....they are in just about all late model cars.
  10. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    I replaced the fuel tank in my 73 Maverick. I replaced it with a new tank for a 64-65 Mustang. Had to shorten the straps a bit. The tank does not come with a vent. Other than that, No other issues. It was just a little over $120 from CJ Pony Parts.
  11. 71gold
    did you use your...filler neck and sending unit?
  12. wolfheads
    wolfheads MadMav
    Florida
    I used my own filler neck. The tank came with the sending unit.
  13. 71gold
    one wire or two?
  14. wolfheads
    wolfheads MadMav
    Florida
    One wire to the unit, one ground to the frame. The gauge works fine.
  15. wolfheads
    wolfheads MadMav
    Florida
    I found the tank and sending unit I installed. CJPony Parts. Part# FSU1 (fuel sending unit) ($32.99). Part #FT2 (16 gal tank w/drain plug) ($100.99). Not a bad deal for both. Hope this was helpful.
