Speedometer Bouncing Around
Discussion in 'Technical' started by 70greenmeany, Jan 25, 2019.
  1. 70greenmeany
    70greenmeany Member
    Hey the hubby has a 1970 Maverick. The speedometer started bouncing around tonight. Do you have any ideas of what could be causing this issue?
    Thanks
  2. Krazy Comet
    Dry speedo cable or possibly dry bearing in speedo.
  3. Acornridgeman
    Wisconsin
    You do not have your location listed. If you are in a cold climate, it might just be the cold.
    They can be cleaned and lubed. Use bicycle cable lube for best results. Then a dab of white lithium on the cable bushing on the speedo head.
  4. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
  5. 70greenmeany
    70greenmeany Member
    I'm located in Cypress, Tx(suburb of Houston)...so not that cold, but it has been in the 30s-40s as of late
    I really appreciate the replies back. I will let him know your suggestions.
    You guys rocks!
    Thanks!
