Splicing RCA cable?
Discussion in 'Audio' started by mashori, Apr 20, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    can I splice RCA cable? For example, if it's too long can I cut a section out and shorten it?
  2. maverick75
    Yes, i've done it many times. Just do a good job at soldering it back together and you'll get good audio.
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Yeah pretty strait forward. Just take your time and dont overheat the wire.
  4. sierra grabber
    sierra grabber Certifiable
    northern nevada
    shortening and re soldering on the end is no big, as for splicing pieces in or wires together, that can cause sound degradation so i suggest going too long as you have and putting on a good end with a GOOD solder connection. if you want to t off then buy a t adapter
