Sport Mirror Gaskets
Discussion in 'Technical' started by tom butas, Sep 14, 2006.
  1. tom butas
    tom butas Member
    West TN
    Sold my 1974 Comet - Looking super nice 73 Maverick near Memphis
    Just got a well used set of sport mirrors. Where can I find the rubber gaskets? Instructions on how the get the glass out to clean, sand and paint. Also need the remote nut and back plate.
  2. blugene
    You might be able to slide the cable down and tape it off. I took one apart and you need to take note of the colors and the routing of the wires, take a good pic if you can. might also spray the cables with some PB blast and let them soak for a bit, get them cables working good before you paint it if you decide to leave it together and taped off. I only have a nut, no back retainer. I thought I saw that available through AK but not certain. Good luck...:cool:
  3. Craig Selvey
    Behind the mirrors are phillips screws so you can remove the mirror.
    I wouldn't remove the cables. Just pull the mirror out of the housing a little ways and mask it off.
  4. 19BlacK77
    19BlacK77 Member
    Here are some pics that show how to take them apart. The first pic shows you where the screws are to take off the mirror base's. The second pics shows where the screws are to take the mirrors out of the remote mirrors. The third pic shows you where the screw is to take the mirror out of the manual mirrors. The last two pics are how I remembered where my cables go back to after I took them out of the housing, I just color coated them before I removed them. I myself didnt have any trouble taking them apart, but I would suggest being very careful when getting the screws out of the remote mirrors, they can be hard to get to. I hope this is what you were looking for.
    Isaac
  5. tom butas
    tom butas Member
    West TN
    Thanks for the detailed pictures. Yeh, tape and pull out to clean..looks like the way to go....Just need to find some gaskets....are the Mustang ones the same?
  6. skaz
    skaz a.k.a. Steeb
    Phoenix, AZ
    74 Maverick, 73 El Camino
    Just found the dog chewing on my shoes, and that gave me an idea.
    Buy some black Dr. Scholls inserts and cut the gaskets out of that. Less than 5 bucks.
  7. Craig Selvey
    No Mustang gaskets are the same....I have looked. Got to find used ones. Or bug AutoKrafters to repop them.
  8. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Mustang sport mirror gaskets are not exactly the same as Maverick sport mirror gaskets, I tried it and it does not sit flush to the base or the mirror. You would have to try heating it up and flexing it to correct the problem. But I was able to find a set of used Maverick gaskets so I did not purchase the Mustang ones.
  9. tom butas
    tom butas Member
    West TN
    OK someone out there must have a set?
