Spring Perches
Discussion in 'General Maverick/Comet' started by mjm0395, Jan 22, 2015.
  1. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    What are they and what do they do? what are the adva. of roller spring perches?
  2. dyent
    dyent Member
    vancouver bc
    click on the link below and will give you a brief description of what they are and do..........
    http://opentrackerracingproducts.com/rollerperch/
    read their FAQ's regarding roller spring perches, how they work and whether or not you will notice any difference etc..........
    I have them and I am very happy!
  3. rthomas771
  4. mjm0395
    mjm0395 Member
    Everett wa
    So are they on top of the shock towers?
  5. rthomas771
    On the bottom of spring
    [​IMG][​IMG]
  6. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
    Wow, what a difference in price between the two!
  7. mjm0395
    mjm0395 Member
    Everett wa
    I saw that, any reason?
  8. Mel Moeller
    Twin Falls Idaho
    Boy, I have no idea. Maybe Jeff knows why the price is so far apart.
  9. Krazy Comet
    Dismal Swamp
    Unless you'll be autocrossing the roller versions really aren't necessary... The rubber ones were fine for years and orig are still in my Fairlane, I'll likely be replacing them with the Scott Drake pieces...
  10. dyent
    dyent Member
    vancouver bc
    anything you can do to reduce friction, will allow the suspension to work better, now whether or not you want to pay that much for roller spring perches.......go read their FAQ's and you can decide! I am very happy with them........
    I have all of Opentracker roller products on my 73 Comet, along with higher rate springs, Koni Shocks, front/rear sway bars and yeah, I can really feel the difference in how the car handles, compared to non-rollerized stock bushing type Upper/Lower control arms and perches.
    FYI, I installed the roller spring perches first, just to see if I would notice any difference and yes, there was! Then, I installed the Upper/Lower rollerized control arms and again more improvement, but not as noticable as when I did the spring perches.
    All comes down to what you want to do or have your car do.........
  11. dyent
    dyent Member
    vancouver bc
    Roller spring perches are hand built, John (Opentracker) starts with Scott Drake regular perches and then modifies them to roller. Nice thing about them, will literally last forever and can be rebuilt by changing the sealed roller bearings. Never have to worry about greasing, squeaking........
    Paul Masson likes this.
  12. Paul Masson
    1971 Grabber
    The Scott Drake pieces are still 'bushed', not roller bearing units.
    From the Link:
    These are made with synthetic elastomer bushings which are similar to polyurethane
    I bought a set from Opentracker for my car. One less area for squeaks and binding... :thumbs2:
  13. rthomas771
