squeeky spring seats
Discussion in 'Maverick/Comet Projects' started by Gary Stewart, Dec 6, 2017.
  1. Gary Stewart
    Gary Stewart Member
    north carolina
    74 comet gt
    I have squeaky spring seats..any easy cure to stop also leaf spring bushing squeak..pretty commom however there must be a quick fix?/ any help on info cure
  2. 71gold
    a lot of times the a arm shafts are the squeekers. the spring seats are rubber mounted.
  3. Hotrock
    Munroe Falls, Ohio
    Concerning the leaf springs, I assume you have a front bushing squeak. With the rear of the car properly/safely supported off the ground by the sub-frame and the differential lightly supported on a floor jack, remove the front bushing bolts one at a time and lube the bolt with grease then re-install the bolt. No more squeak!
