Stainless steel spray paint not to bad
Discussion in 'General Maverick/Comet' started by x72COMETx, May 6, 2015.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    Well i couldnt stand looking at my pitted rusty old rear bumper so i pulled it off and decided to paint it, i didnt want to go with the CHROME spray paint since it looks more aluminum so i found this stainless steel paint by dupli color and i must say it doesnt look to bad, its almost like a metallic flake.
    injectedmav, 71gold and biggruss like this.
  2. z28th1s
    Lynchburg, VA
    Looks pretty good from what I can see.
    Got a more close up picture?
  3. mav1970
    Looks good - one of the best bumper spray colors I've seen :thumbs2:
  4. Bad Brad
    Bad Brad Member
    Coleraine, MN
    74 maverick
    Looks great in the pic. I would also like to see some closer pics.
  5. 71gold
    looks like a nice color for some frontend parts...:thumbs2:
  6. x72COMETx
    x72COMETx Member
    Vallejo CA
    Here ya go
    z28th1s likes this.
  7. z28th1s
    Lynchburg, VA
    Does look good.
  8. bmcdaniel
    I used that to paint the center spokes of my sport steering wheel, came out decent, too.
  9. mav1970
    Thanks for that reply - I will have to get some of this paint for that same purpose :cheers:
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    Just make sure your last coat is a full wet coat so the protective resins will rise to the top before setting up. Dust coats don;t hold up as well and color can even change slightly as well. This "full wet coat" provides the protective layer that helps to avoid discoloration and smudging of the base colors metallic frits. Heating the can in hot water prior to applying heavy full wet coats helps to avoid runs too.
    Basically, spray "hot and heavy" and then hit it with a fan immediately afterwards to avoid sags a runs.
    Bad Brad and injectedmav like this.
  11. mav1970
    Thanks for the tips :tiphat:
  12. groberts101
    groberts101 Member
    Minneapolis, MN
    Yep, right back atcha', bud. Just sharing the trials and errors of nearly 30 years of painting with brushes, guns, and cans. Lots and LOTS of errors.
    Also just paying it forward for all the helpful tips you and others around here so graciously give us, Bob. :thumbs2:
    injectedmav likes this.
  13. Lee Richart
    Lee Richart Member
    Redford, MI
    1973 Maverick LDO 421W
    Yes, looks very good and a little bit cheaper than a rechrome.
    Lee "THE MAV" Richart
