Stallion steering wheel
Discussion in 'General Maverick/Comet' started by pegleg1858, May 7, 2012.
  1. pegleg1858
    pegleg1858 Member
    kentucky
    69 1/2 maverick
    Did they have a horn in them? Just installed one from a cobra mustang that looks the same minus the center cap. No horn inside the cap. Not even a place for one.
  2. darren
    The later models Fairmont, Mustang etc had the horn on the turn signal lever. Push it in.
    So those wheels dont have a horn button on the steering wheel.
  3. mercgt73
    mercgt73 Member
    Like Darren said, the Ford Sport Steering wheels came with and without center push horn pads depending on the model/year. A quick way to tell is to flip the wheel over and see if the base has the horn slip ring contacts. You can make a non-horn pad steering wheel into a horn pad steering wheel, someone on here did it...
  4. simple man
    simple man Member
    Bunnell,Florida
    I hated that horn switch in the turn signal handle! You either turned on one of the signals or totally forgot where the damm thing was! :naughty:
