Starter soloenoid replacement
Discussion in 'General Maverick/Comet' started by mrcomet, Feb 6, 2013.
  1. mrcomet
    mrcomet Member
    Florida
    1971 comet gt
    Hello,
    Any recomendations on a quality starter solenoid replacement that is fender mounted with 4 terminals.
    Anybody ever used the Napa Eichlin brand?
    Thanks for the suggections.
  2. scooper77515
    Aren't they all pretty much the same? You can get them at NAPA, AutoZone, O'Reilly, etc.
    They will wear out over the years as the plastic bodies go through several heat/cool cycles, and crack. Then time for a new one.
    I think my last one was $12??? :huh:
  3. don graham
    Napa is usually pretty for quality parts.
  4. rthomas771
    The cheap ones use aluminum or tin instead of copper guts and steel nuts instead of brass
  5. schroensr
    schroensr knight Runner
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Look at rock auto parts. You can tell by how cheap they are by price an how they look. Napa brand is very good.
  6. 71gold
    our NAPA store sells about the same quality as... AutoZone, O'Reilly, etc. just at a higher price...:yup:
  7. scooper77515
    I kinda figured that, as well.
    I just had to buy a PCV valve for my truck, and they had them for about $29. AZ and O'Reilly had it for $12 and $15.
    I paid the $29 because only Napa had it in stock, and the other guys had to order it, and I needed it ASAP as it was contributing to the failure of my IAT sensor, causing the rough idle.
  8. coutangman
    coutangman Member
    Charlotte, NC
    NAPA is usually higher than most other auto parts stores. So is Carquest. Try Advance. We sell them every day there.
    Jim
  9. coutangman
    coutangman Member
    Charlotte, NC
    Good advice. I had one go out on my trip to Ky this past summer. Fortunately, I had an extra in the trunk.
    Jim
  10. 74LDO
    74LDO Member
    Ohio
    1974 Maverick LDO
    failure
    Really? How did your solenoids fail? I have never had one fail....Really not trying to be a smart azz here I've just never had one fail.:huh:
