Starting problems HELP
Discussion in 'Technical' started by Acedmav75, Sep 7, 2009.
  1. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    I have a 75 mav 2 dr and lately when i go to start it it doesnt start first time and you hear a pretty loud grinding sound. Do i need to replace the starter? And if i replace the starter should i replace the alternator as well? HELP ASAP PLEASE:bowdown: thanks!!!
  2. Mavman72
    Sounds like you have a weak starter (not engageing the flywheel completely)hence the grinding sound...Or you hava a dead spot on the flywheel or alack of proper voltage to the starter.Why replace the Alt? doyou have a charging system problem as well???
  3. Acedmav75
    Acedmav75 Member
    Miami Florida
    Maverick
    Nope i dont i was just figuring maybe since thats going, maybe i should replace the alternator lol. I was pretty sure it was the starter i just wanted to double check. Know of a good long lasting starter?
  4. bayareamav
    bayareamav Member
    san francisco bay area
    1973 maverick
    i just replaced mine with some overr the counter one from Kragen, it came with a life time gaurantee for about $60 with the core, i also replaced the solenoid at the same time, most good parts stores should carry them
