Starting problems
Discussion in 'Technical' started by Shades, Feb 15, 2010.
  1. Shades
    Shades Member
    Bay Area
    1972 maverick
    i ve got a problem with my mav it doesnt want to start. i have changed the ingnition switch and the battery not to long ago and i just took the starter to kragen to have it checked so i dont have a clue.:hmmm:
  2. Boosha
    Boosha Built to run hard
    Buckeye State
    69.5 Maverick,1964.5 Mustang,1966 T-Bird
    are you getting spark/fuel?if you have them,have you checked the points?
  3. stmanser
    Davenport, Iowa
    well you need spark and fuel for the motor to run.
    most important thing.. did it just stop all of a sudden.. or has it been like this a long time.. has it ever run, etc..
    we need more details, but here are some starting points to check into
    Take out the #1 spark plug, leave it connected to the plug wire.. does it spark when trying to start it?
    if it sparks, you have spark (but not necessarily a guarantee, because it could be not enough, timing is off, etc.)
    take the fuel line off the carb, put it into a catch can.. when you attempt to start the engine, does gas start coming out?
    if so, thats a good sign.
    have someone step on the gas pedal while you are looking down the carb, is all the linkages working, butterflies opening, and can you see fuel squirting into the intake?
    things to look into, let us know what you did and what you observed while troublshooting..
    good luck
    figuring it out is half the fun
  4. Dave B
    Is it turning over? or not....
  5. Shades
    Shades Member
    Bay Area
    1972 maverick
    not it isnt even turning over checked the cables cylinoide everything. when i try to start it it just makes a click noise and its done. and i had it running it just started a couple days ago
  6. Dave B
    Put a volt meter on your battery, check the voltage, just sitting, and then while cranking. Have you had the battery checked ? or can you boost it and see, if it'll start?
  7. Mavman72
