Steering column interchange
Discussion in 'Parts Interchange' started by joerockne, Jan 16, 2020.
  1. joerockne
    joerockne Member
    Norman, OK
    1972 Grabber Maverick
    Do 2 door and 4 door columns interchange? Also, do all years interchange? I need to find a column for my 1972 Grabber.
  2. 71gold
    :Welcome:...:Handshake:
    I would think the best way to see what one would fit would be check the...ing. switch. I think there were 3 different ones.
  3. joerockne
    joerockne Member
    Norman, OK
    I could have bought another mostly complete 72 4 door for cheap. Probably should have done it. I need a driver door glass and rear quarter glass. So I am hoping to find a parts car with that stuff too.
  4. Krazy Comet
    Columns vary by transmission but in any given year are identical. In other words all column automatics in '72 are same. They can vary by year, but usually isn't enough difference to prevent swap. Exception would be early '70 that have ign switch in dash.
  5. joerockne
    joerockne Member
    Norman, OK
    Ok thanks. Still looking for a local parts car that has the stuff I need.
  6. rthomas771
    Not all Maverick columns are the same
    Turn signal switch is different
    Ignition switch is different
    Top of column is different
    Wiring harness at column is different
    Shift lever is different, but will interchange
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    mojo, Wilbur Green and 71gold like this.
  7. joerockne
    joerockne Member
    Norman, OK
    Thanks. Some genius made there own adapter for a Superior 500 steering wheel. They drilled holes in the side and top of the threaded piece and welded it to the threaded shaft you see in that pic with the turn signal cam.
  8. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    That “genius” should be beaten with the column!
  9. joerockne
    joerockne Member
    Norman, OK
    Agreed. Now you can't even take it apart and put it back together easily. It's potentially a big enough pain in the a$$ that I will just replace it .....
    BBMS18 likes this.
  10. Acornridgeman
    Wisconsin
    Joe,
    If you can grind off the welds or get the threaded tip of the shaft cut off, so you can take the column apart, it would be easy enough to rebuild it with a different shaft. I have a decent shaft if you want it. Just pay for the shipping.
    Maverocket, BBMS18 and 71gold like this.
  11. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I may have the old one out of my 72 Comet if you are interested. I cannot remember how complete it is.
  12. joerockne
    joerockne Member
    Norman, OK
    I appreciate it guys. What would it cost to ship that threaded shaft to 73026? I know I can cut off the shaft if I take the column out. thanks again. -Joe
  13. Acornridgeman
    Wisconsin
    I did a quick FedEx home delivery calculation and looks like under $20 - which is way better than the post office. Package would be about 7 pounds.
    If interested, PM me and I'll get you the details.
  14. joerockne
    joerockne Member
    Norman, OK
    PM sent.
