Steering Column replacement
Discussion in 'Technical' started by charlie9049, Jun 20, 2016.
Tags:
  1. charlie9049
    charlie9049 Lorenzo
    Navarre Florida
    1972 Comet
    I have a 72 Comet with a worn out column. What I would like to do is replace it with an aftermarket tilt, floor shift version, blk powder coated with Ford wiring to plug into my harness. Does anyone know off hand what diameter and length my column is now. Also if I were to order a Summitt column do I need to order a special kit to adapt to my Comet. My car was a column shift so it has the linkage bar on the firewall side that isn't being used. What have other members bought to replace their column that was a easy fit? Thanks
  2. Craig Selvey
    I know of NO aftermarket column that fulfills all your needs/desires.
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Size of the Steering Shaft ... You'll probably have to break out your measuring tape and after getting the size .. call IDIDIT .. they make a whole bunch of different sizes .. some for Mustangs and I'd wager that you would be able to
    locate a shaft that was really close to what you already have and you could ' modify ' a new column to your specific
    needs.
    Cometized
    (Chip)
  4. rlbriggs7212
    rlbriggs7212 Member
    Grass Valley
    1972 Maverick 64 Fairlane 52 Henry J
    I called IDIDIT and they wouldn't give me the time of day unless I was working on a try 5 Chevy. I don't know of a GM column harness that will plug into a Maverick . If any one does let me know. Good luck.
