Steering Column
Discussion in 'General Maverick/Comet' started by MaverickMan34, Jun 15, 2009.
  1. MaverickMan34
    MaverickMan34 Member
    Kansas City
    1970 Ford Maverick
    I was wanting to know if i can remove my little shift bar on my steering column because I'm putting in a floor shifter. And if so, how?
  2. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Um.. I think there is a pin holding it in.
  3. 71gold
    is it auto or 3 speed? key on the dash?
    ...:huh:...
  4. Earl Branham
    Lugoff, SC
    You can remove the shift handle, grind or zizz wheel the shifter handle boss off of the collar, and do the body working with fibreglass or bondo. Did mine with fibreglass and you can't tell it was ever there.
  5. MaverickMan34
    Kansas City
    1970 Ford Maverick
    Its an auto and key on the column
  6. 71gold
    you will also have to relocate your...backup/netural saftey switch..
    you will need to lock out the collar so it doesn't rotate and cause a...no start situation...
    Earl had a trans mount saftey switch on his car...(y)
    ...Frank...
