Steering problem
Discussion in 'Technical' started by mashori, Jun 29, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    posting for a friend with a 4door 74 mav. He says that recently when he is turning the steering wheel it only grabs to turn the wheels on the second pass around in a full circle. After it grabs the wheels to spin it slips. He says it's not safe to drive. When he got the car it had the power steering removed.
  2. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    Sounds like a stripped steering box gear..
    I have a complete p/s setup (used) available if he is interested , have him shoot me an e-mail or pm.
  3. Bryant
    i have a spare stearing box. he needs to have somebody turn the wheel while he watches the stearing shaft turn in the box and see when the pitman arm starts to move. that should verify that the box is where the problem is.
  4. RobbieG.
    RobbieG. Member
    Phoenix Az.
    75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
    Is the rubber between the stearing shaft and the box broken?
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    is it safe for him to drive it to a shop or should he get it towed?
  6. mojo
    If I had doubts abt steering safety I wud have it towed.
    JMO
  7. Bryant
    if it takes a full turn of the wheel then it is not safe to drive. definitly get it towed.
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'll relay the message . . . is it hard swapping the steering box?
  9. Bryant
    not to hard. 3 bolts on the stearing box. one bolt on the stearing colum. the hardest part is the pitman arm. it takes a special puller.
  10. Bryant
    i can bring the stuff with me tomarrow and do it at the shop if your friend wants.
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I sent him a text, see what he wants to do. It's this guy I ran into in the Del Mar area. He drives a sweet black and red 4 door, the guy is our age, maybe younger.
  12. Earl Branham
    Lugoff, SC
    Have him check the rag joint first. Much easier to replace, and about $10.
  13. Craig Selvey
    Dittos on the rag joint.
