Stick Shift Converion Questions
Discussion in 'General Maverick/Comet' started by JDM_GUY, Feb 5, 2009.
  1. JDM_GUY
    JDM_GUY Member
    San Francisco
    73 Maverick 2 door coupe, 75 JDM celica coupe, 75 JDM celica liftback, 93 ford probe GT
    im in the process of converting my maverick into a stickshift.
    1) first thing id like to install is the clutch depal, can someone post a pic of where the clutch rod goes through the fire wall and a picture of where the rod is through on the engine bay?
    2) can someone post a picture of where the frame side mount is supposed to be mounted?
    3) how the Z bar is connected with other components?
    4) where in the engine is the engine ball stud is mounted?
    5) will a Inline 6 stick shift harness out of a maverick will work for a V8 maverick stick shift?
  2. JDM_GUY
    JDM_GUY Member
    San Francisco
    can anyone help, id like to know how everything is connected by image.
  3. Kutlass
    Kutlass Member
    Pasco, FL
    1972 Comet and a 1978 f150
    I second this question. I want to know that too.
    I saw this thread and said "that will be helpful". But no ones answerd so not to much help.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Probably because there is a dozen threads on this topic if you use the search ...
  5. JDM_GUY
    JDM_GUY Member
    San Francisco
    searched around already, especially in the article write up area... found no pictures. unless im searching with wrong key words:oops:
  6. dmhines
    Cumming, GA
  7. JDM_GUY
    JDM_GUY Member
    San Francisco
    :urock: thank you very much for the infos.
  8. Kutlass
    Kutlass Member
    Pasco, FL
    cool thanks alot!
  9. JDM_GUY
    JDM_GUY Member
    San Francisco
    will a original inline 6 motor maverick in manual work with a v8 maverick manual?
  10. dmhines
    Cumming, GA
    Pedals are same .... all the linkage inside the engine compartment is different ...
  11. JDM_GUY
    JDM_GUY Member
    San Francisco
    :oops: opps let me rephrase....
    will a HARNESS out of original inline 6 motor maverick in manual work with a v8 maverick manual?
  12. dmhines
    Cumming, GA
    You talking about the harness for oil pressure, water temp, etc ??? You should get a V8 harness so everything is he correct length and location. Auto's and Manuals have same harness ...
