sticking door
Discussion in 'Technical' started by Vinchez78, Oct 13, 2018.
  1. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    My driver side doors works sometimes meaning it'll open and close and lock, and majority of the time it won't budge at all, so ill either have to dukes of hazard into the driver side window or go in through the passenger door, is this a major fix or something some WD-40 can handle?
  2. 71gold
    does the door sag when it's open? with the door open raise up on the door by the outside handle. excess play can jam the door when closed. if so new hinge pins and bushings need to be installed.
  3. Vinchez78
    Vinchez78 Member
    Columbus GA
    1973 mercury comet
    I don't think it sags, it's more like, it just won't open, I'll double next time it does open if it sags
    71gold likes this.
  4. Krazy Comet
    Sagging is usually obvious, generally causes closing problem long before opening issues.
    Probably linkage inside door is dry/worn and/or mis adjusted.
