Strg in general
Discussion in 'Technical' started by mrbrooksy, Dec 8, 2011.
  1. mrbrooksy
    mrbrooksy Retread
    Motor city
    72 maverick,99 cherokee,2000 cherokee.80 suzuki ts 250 and a minivan
    I am new to this forum have a 72 2dr v8 man drum brakes,pwr strg, a/c mav.
    the pwr strg pump is shot the power valve is leaking and sloppy,the pitman arm is wore out tie rods need replacing . I have heard of converting over to manual strg.seen the adapter sleeve,would i need or was there 2 different gearboxes or just the power adder valve, do i need the different box? also what does anyone know about scarebird disc conversion brackets and instructions anyone use it ?any good? enough rant for now would appreciate some input .which club is better or join both?
  2. baddad457
    You would be better off replacing all the steering parts with new manual steering parts. New pitman arm, new drag link, new tie rod ends. All these parts are available new from Autozone and Advance Auto (Autozone is usually cheaper) Vendor that makes these parts is "Rare Parts" It's not going to be cheap, but you'll only have to do it once. You can keep the power steering gear box with it, the only difference was the gear ratio.
  3. Craig Selvey
    Welcome aboard.
    You are in luck. The Maverick Comet Club International, Inc. (MCCI) will be holding their 19th Annual Roundup Nationals in Dearborn, Michigan next July 24-29. You will see lots and lots of Mavericks and Comets. You will have to plan and attend. More details can be found at www.MaverickCometClub.org
  4. rayzorsharp
    Welcome aboard! :Handshake
  5. Resto
    Resto Benders Evil Twin
    Yuma AZ
    :Welcome:From SW Arizona. This is the best forum for anything you need. Each region of the world has its own clubs and Meets.:drive:
