subframe connectors
Discussion in 'Technical' started by Positively Ralf, Jul 14, 2010.
  1. Positively Ralf
    Yonkers, NY
    1974 Maverick
    I know these are mainly to stiffen up the chassis/frame of the car but do you guys suggest these even for a weekend car with an i6 in it? If so, anyone have a link of where they may sell them for me to purchase?
  2. maverick75
  3. Craig Selvey
    It will stiffen the ride. If you are not going to drag race the car, they are a waste of money in my opinion.
  4. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    x2 in fact they will take away some ride comfort.......
  5. Earl Branham
    Lugoff, SC
  6. Bryant
  7. CornedBeef4.6L
    no longer here
    on a totally stock car they just make it ride rougher.....now add some kyb shocks, bigger sway bars, some bigger tires and rims, etc....then yes it will feel better with bars.....it is just stuff working in conert.....if you stiffen it up fvrt and back it makes sense to do the middle......
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    Slightly off topic, I have a set of the Starnes connectors that I have not installed yet. Can I weld those in without melting the carpet ? Or do I need to remove the carpey prior ? I do not have the instructions anymore and can not seem to remember the actual welding points. Thanks All, Scott
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Scotty, I suggest you weld them in with carpet out. And you just grind the ends to match your subframes the best, then put a bead around the entire sf connector. If you work around you wont get the floor so hot in one area. Car needs to be on its wheels to install them, like on a lift that you drive on.
    And back on topic, I dont think a stock 6 banger needs them. Just my opinion.
  10. Scotty P
    Scotty P Member
    santa rosa, ca
    Thanks Dan!
  11. Earl Branham
    Lugoff, SC
    Yeah, guess you would need all those pieces to get full effect from the bars. I have all that and didn't take it into account. Sorry Craig!
  12. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    I'm putting in some eventually, but right now I'm focused on tightening up the front end (entirely new components/disk brake swap) and I just finished the rear end. I've got KYB Gas-Adjust shocks all the way around, and I'm putting on a bigger front sway bar, and a rear sway bar. I'd say your money is probably better spent elsewhere at this point though. Disclaimer-I am nothing remotely resembling an expert.
  13. captainmack
    captainmack Quad Door
    A six is faster than an 8. Around corners and on windy roads that is. It's lighter. Stiffen that sucka up!!
  14. jmgford
    jmgford Member
    Iowa
    Really? I did not know that. Thanks.
  15. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    this is true accept I think it'd need the suspension stuff like subframes/sway bars/tubular a-arms more so then a v8 due to how the weight of the i6 overhangs in the bay compared to a v8..
