swap plan, Power ???'s
Discussion in 'Technical' started by 71mavkidd, Jun 13, 2009.
  1. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    ok, i am finally starting to legitamately plan my swap to a 302. i am wanting to be in the 300 hp range am planning on HAVING my engine built up. does anyone have an idea of what i should have done and ballpark what it will cost?
  2. 71_Maverick
    71_Maverick Member
    michigan
    if its a ho 5.0 do what car craft did and put a set of afr heads, got the article said with just the heads it made 400hp i dont know what it would be to the rear wheels though. good luck with the swap
  3. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    you would lose about 20% through an auto and about 15% with a manual.
    afr heads with headers,intake,carb and such should easily get 300 hp,more with a cam.
  4. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    with the new power coming from a i6 200 i realize i will need a new radiator, what would be my best option there?
  5. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    the aluminum rad offered through this forum would be youre best bet
  6. rayzorsharp
    By all means...I own two of them. :)
  7. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    i got the 2row run, if i knew the 3 row rad would have made it out so quickly i would have held off
  8. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
