swaping efi 5.0 ??? about thottlebody spacer
Discussion in 'Technical' started by jaxster010, May 20, 2012.
  1. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    ok iam swaping a efi 5.0 into my maverick and i was wondering if i can take that stock spacer thing out so i can mount thottle body strait on intake manfold so the intake pipe want hit shock tower
  2. baddad457
    I don't see why you can't if you're going into an older car. As long as the computer can do without the EGR, it shouldn't be an issue.
  3. Bryant
    the spacer holds the bracket that the throttle cable mounts to.
    accufab sells a 1/4" thin spacer that will do the trick for you.
