Sway Bars
Discussion in 'Technical' started by gwil81, Oct 9, 2008.
  1. gwil81
    gwil81 Member
    oakland,ca
    1977 maverick
    Will a rear sway bar make a change ? Is the stock v6 sway bar the same as a stock v8 ? If i wanted to go bigger how big can I go? The biggest I found was 7/8" . An i want to be aleast 1" right :16suspect ? for 7/8" the front and rear $119 each with s&h at http://www.justsuspension.com/ :yup:
  2. rthomas771
    You don't want a larger sway bar on the rear than you have on the front. 1" up front and 5/8" on the rear will be more ballance or 7/8 front and 1/2" rear
  3. Beerstoreguy
    Beerstoreguy Member
    St.Petersburg Florida
    1973 Comet
    I have 1 1/8 front, from a 65-66 mustang. The front mounts need to be moved 1-2 inches foreward. I think it was worth the extra trouble, with cut 620# mustang springs the car turns wtih verry little body roll.
  4. PaulS
    Have you got the matching 7/8" rear bar?
