swaying issues
Discussion in 'Technical' started by tommyboy, Jun 11, 2019.
  1. tommyboy
    tommyboy 77 mav
    parkersburg west virginia
    1977 maverick
    i have a 77 maverick that I cant keep on the road wants to sway all over im hoping you guys can give me a clue what to fix plus hitting bumps makes for a rough ride any help would be appreciated
  2. mojo
    You need to give more info on what steering & suspension you have had examined by alignment shop, and/or what you have replaced. Sounds to me, you have an issue w/ worn parts.
    BBMS18 and stumanchu like this.
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Mavericks never handled great from the factory, but as old as it is, your shocks may be worn out, and your stablizer bar bushings are likely shot. Polyurethane improves performance there.
  4. Krazy Comet
    Agreed, worn steering and/or suspension parts will cause poor handling, pulling, wandering etc.
    If you're not familiar with steering and suspension, have a competent shop look at it. Unfortunately those are often few and far between, BUT a shop that handles early Mustang should have no problem. Most of the components are same for both.
  5. stumanchu
    stumanchu Stuart
    Portland, OR
    Can you do the work or have to hire someone? There are a lot of pieces that wear out. If you have trouble with going straight, you might start with tie rod ends and the idler arm bushing.
