T-5 conversion
Discussion in 'Transmissions' started by BossMaverick87, Nov 30, 2009.
  1. BossMaverick87
    BossMaverick87 Member
    California
    Maverick with cougar taillights
    I have just completed a C4 to T5 swap using Mustang Steve's cable clutch set up. However, the cable literally rests up again the exhaust manifold. I seems to be the only way that I can fit the cable, but I'm wondering if either the cable will be fine tucked in between the manifold and the shock tower, or if it can be rerouted for a better, less heat exposed area. Thank you
  2. brainsboy
    brainsboy Member
    Tampa
    What about some header wrap placed around the cable to protect it?
  3. Bryant
    the cable will not last long touching the manifold. i dont know anything about that kit but you will need to do something to get it off. you can try use a heat wrap of some sort but if its touching i dont think a heat wrap will be enough.
  4. 302-72-mav
    302-72-mav Member
    sactown CA
    just put some exhaust wrap around the header where the wire hits it but put a lot of it
    or make some hangers / brackets so it does not hit it
  5. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    When this cable burns up, go get yourself a 2003 mustang clutch cable. Its a little longer and should solve your problem.
