T-Stat ???
Discussion in 'Technical' started by 71gold, Mar 27, 2007.
  1. 71gold
    i am thinking about drilling a hole in my T-Stat to keep it from ...air locking...
    are there any problems that i might fine later by doing this?:huh:
    carbed 5.o...roller motor...180 T-Stat.
    ...:cool:...
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Frank,, it is my new policy to do that with all my old cars. I dont believe you can go wrong.
    Dan
  3. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Sounds like a good move to me(y)
  4. Mavaholic
    I like the aspirin trick.
  5. 71gold
    ...and that is???...take 2 and call someone in the morning...:p
    ...wouldn't you have to pull the T-Stat every time you drained the water for some reason??
    ...:bouncy: ...
  6. DGerhardt
    DGerhardt Member
    Kentucky
    1970 and 1975 Mav. 1961 F100
    The asprin trick is to put 2 asprin (or break one in half) in the thermostat. Force the therostat open and gently let it close on the asprin. This will hold the thermostat open while you fill the cooling system and the air will self bleed on start up. The asprin will disolve and the thermostat will work as intended.
    The hole trick works to but is not as fast and easy. Just remember to use a small hole, you only need enough to bleed the air on initial start up.
    Dave
  7. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I've heard that a 1/16" hole is perfectly fine.
    my :2cents: :2cents: :2cents:
  8. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I put the hole in my Grabber T-stat ... and also in the T-Stat I just put in the F150 ...
    Frank ... I have the same setup ... roller motor ... carb ... 180 T-stat .... and my gauge never goes above 180/185 ...
  9. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    Can someone post a pic of where the hole is supposed to be drilled?...
  10. dmhines
    Cumming, GA
    I just put it at 12:00 on the lip of the T-stat ...
  11. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You can also buy a Thermostat with a integrated bleeder valve.
    I use a tool that pulls a vacuum on the system by using shop air. Allows you to check for leaks before you install coolant. After your satisfied there are no leaks you drop a hose in the coolant jug and flip a lever and the vacuum inside the cooling system draws the coolant in and prevents air locks.
  12. mean_maverick
    most of the dodge/chrysler t-stats have an integrated 'hole' in them, but i think they're all 195*
  13. NICK DOMINICK
    Burke, Virginia
    I just put a 1/16" hole in mine at 12:00 and will see if it works.
  14. T.L.
    T.L. Banned
    Southern Colorado
    Well, my new T-stat came with an air bleeder hole already in it, so I see no point in drilling one...
  15. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    I honestly have never had a problem with air on windsor fords. Other applications, yes, but not windsor fords.
