Taurus fan
Discussion in 'General Maverick/Comet' started by smegnl, Sep 6, 2020.
  1. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    What year Taurus fan do I need to get to use in my Maverick? I saw a lot of threads on here about getting one, but none mentioned the year.
    Thanks.
  2. 71gold
    90 ish from 3.8.
    smegnl likes this.
  3. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Mine is from a 94 Taurus 3.8, but I think they were used from 92 - 95 on 3.8. You can probably still buy the whole assembly new. One of the best upgrades I ever did on the Comet.
  4. ike72com
    ike72com Member
    Charleston SC
    Best to measure room you have with a tad to play with.
    Works for some, not for some.
  5. 71gold
    did you turn it upside down?
  6. ike72com
    ike72com Member
    Charleston SC
    I dont remember what year tarus i got mine out of but i thought i scored big. Fan almost hovered on battery on floor.
    I got rad in and its a no go. Tried every which way but loose Sir.
    Like squeezing a 300 lbs man in a 32 waist speedo.
    Possibly different thickness fan out there. Best insurance is to measure your space before fan hunting.
  7. bmcdaniel
    bmcdaniel Senile Member
    When I did mine I didn't like that the fan was only 1/4" from the water pump. I think my Griffin radiator is a little thicker than stock, too. I had already removed the raised part of the radiator core support and made it flat. I finally slotted the motor mount bolt holes so that I could slide the whole engine back about 3/8". Now I have over 1/2" clearance. Most will just cut down the fan shroud instead of going through all that.
    rickyracer likes this.
  8. William623
    Orlando
    1973 ford maverick grabber
    I was running the Volvo fan which is the same motor as the Taurus fan, and I didn’t like how big of a draw it had. So instead I went with the black magic 3300 cfm fan. I trimmed the shroud by 1/8” and it fit perfectly. That is on a 2 core aluminum radiator. Works fabulously. I have 1/2-3/4” gap to the water pump pulley F03C551D-EB72-4BF2-972C-D6899B3F7622.jpeg 172C57AB-787D-4A61-8A82-C35544D8D091.jpeg
    mojo likes this.
  9. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
    yikes, $230
  10. stumanchu
    stumanchu Stuart
    Portland, OR
    I had to trim my shroud to get that fan in with a stock 3 core radiator. I have less than a 1/4 " clearance, and the paint gets rubbed off the corner of the pulley front. I used the Volvo relay and BMW temp sensor (80-88C). I plan to install some LEDs so I know what the fan is doing.....someday.
  11. William623
    Orlando
    There was an error amazon and I got it for $120? Or something.
  12. ike72com
    ike72com Member
    Charleston SC
    I got this a year ago. Pulled it from what i thought was a tarus. Must have been a cougar. They call this the MARK-V fan. Too thick for any of my projects. Works great in window. Blows air across garage:lolup:
    Now that tarus fan gotta be thinner.
    CA189HJN, smegnl and 71gold like this.
  13. canuck222
    canuck222 vroom, vroom...
    Woodstock, ON
    '73 Mercury Comet, 302, Auto
    I also had to trim mine and add some L brackets. Ended up replacing it after a year with the champion fan to match the new rad Mod. CC339.
  14. 71gold
    How will you wire these?
  15. 71gold
