Tell me who has done a 5.0/C4 Rod and Custom install successfully.
Discussion in 'General Maverick/Comet' started by scooper77515, Apr 28, 2013.
  1. scooper77515
    Anyone?
    Anyone know of anyone?
    If so, what headers did they use?
    5.0 or 302 with C4 transmission.
    Not 351, Cleveland, AOD, LS, etc.
  2. rthomas771
    Frank started out with a 347 and C4. He used all the headers that Summit had to offer except one set.
  3. scooper77515
    I was really hoping to be able to just drop in a header when I was done. I am getting to old to have to lift the engine, jack up the car, and put them in from underneath.
  4. scooper77515
    Comet fever, what do you use now? Stock manifolds?
  5. rthomas771
    Frank and I didn't move the engine when we put the header's on...they slid right in place.
  6. scooper77515
    Which headers? And would they clear a C4 on 5.0?
    "sliding right into place" is EXACTLY what I want!!!
  7. Dave B
    Too old to work on cars....better find a new hobby, like checkers or something....
  8. scooper77515
    I want to start a new hobby.
    It is called "cruising".
    This working on cars and having them sit in the garage not driveable is killing me.
  9. scooper77515
    "Small stuff"????
    These are HUGE headers, which is why they won't work.
  10. car-nut
    car-nut Glenn
    conn.
    So I have a little different scenario, I have a 5.0 and an AOD. I spent the money and bought my headers from Ford Motorsports. They fit perfect!
    The biggest reason I went that way was that I have the GT40P heads, and getting headers for them isn't really easy. They have P specific headers. They dropped right in place, no clearance issues at all. They are listed for a 5.0 Mustang in their catalog.
    Glenn
  11. scooper77515
    I don't "really want headers".
    I "really want" a car I can cruise in. Ticks me off that I put all this money into a new rack and pinion Mustang II conversion and my parts don't work with it.
    At this point, shorties or stock manifolds are not that much of a problem for me. It will run better on stock manifolds than it will on anything else I have thrown at it at this point.
  12. injectedmav
    injectedmav Member
    Georgia
    Maybe some Mustang K-code style manifolds would be a good compromise.
  13. Dave B
    It's all in research...you need to know what your getting into, before you jump....
    I'm sure Doug Thorleys would fit, but they aren't cheap.....
  14. John Holden
    John Holden Member
    NJ
    Have you checked to see what guys are using with a mustang 2 swap in an early mustang? I'm sure you could find at least a few that put 302's in them and used headers.
  15. Dave B
    There are loads of 5.0L Mustang shorties that should fit, and they are somewhat inexpensive...going to manifolds woul be a step backwards...all this to make the car better, then stock manifolds....yuck.
    Crap, if you were closer, I have a set of Ranger V8 swap headers hanging in the shed, that would probably work, and I'd give them to you.
