Can anyone help me with this question? I have a 200 I6 in the maverick I just purchased. I bought a temp gauge to install but I am not for sure where the stock temp sensor is can someone point me in the right direction?
I think Derrick is thinking about the Oil Pressure Gauge. The temp gauge goes on the back drivers side of the head. It sticks out at an angle.
You got to get them babes away from the car when you need to do some work. They are just too distracting.
Yeah, send them babes MY way. They can pose in MY garage all day long... By the way...I just got A/C run out there, just to keep em comfortable...
it depends if you have a v8 or I6 as far as where it goes, either way it shouldnt be any harder on any engine
you'll want to drain some water out of the radiator and then remove the sensor from the back drivers side of the head, as mentioned in the quote above. once its out replace it with the sensor supplied in your gauge kit and wire it up according to the directions good luck
