the work begins
Discussion in 'Cosmetic' started by stevens, Apr 20, 2011.
  1. stevens
    stevens Member
    getting my floor pans put in saturday then its on to the cowl yee haa:dance:
  2. mav1970
    I did my cowl and it really wasn't as bad as I thought it was going to be. I used a little spot weld cutter that I bought from Harbor Freight for 5 bucks in my drill and that did the job on removing the outer cowl shell. :)
  3. mercgt73
    mercgt73 Member
  4. 72MAVGRABHER
    Roanoke, Va.
    x3.. Do it..
  5. mulberrycop
    mulberrycop Member
    Northeast PA
    76 2 door, 73 grabber, 76 2 door
    Did my '69 1/2- took the cowl cover completely off. On my '76, I cut into the cowl cover. Won't try that again! Totally removing the cover is the way to go!
    Used the same HF weld cutter and lots of oil to keep things cool. Patience is the key.
