thinking of buying a t5 trans.
Discussion in 'Transmissions' started by dgg54u, Jan 16, 2012.
  1. dgg54u
    dgg54u Member
    New Orleans area
    1972 Maverick Grabber
    5 I have the chance to buy a t5 out of a '94 mustang gt. it comes with trans,shifter,crossmember,and bellhousing but 3rd gear is bad all for $150..does this sound like a fair deal?
  2. Dave B
    Do some research before you buy. There are so many variations, and there is a change in the input shaft length around 1993 (?) which can be another challenge. I've bought 2 complete 1989 World Class T5's for $250/ea, in good operating condition.
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Yes jus like Dave said in 94 they changed to a longer input shaft.Make sure you get everything,Bellhousing,fork along with the trans. I think the rebuild kit for a T-5 is around $180.00.... plus labor.
  4. dgg54u
    dgg54u Member
    New Orleans area
    thanks for the info.. he does have the bell but no fork....the seller says the 3rd gear is about $40
  5. Dave B
    These usually need more than a gear, 3 rd is common, but the rest will need work. Like Derek mentioned, Summit & Jegs sell rebuild kits, usually Ford Racing for a reasonable price. Last weekend on the Power Block, they showed a quick rebuild on one.
  6. dgg54u
    dgg54u Member
    New Orleans area
    well, I bit the bullet and bought the trans.. it did come out of a '94 Cobra GT and has the "Z" spec... does anyone have a clutch pedal assy? also a fork for a '94 T5 bellhousing
  7. Bryant
    i got my fork new for 15 bucks from the local auto parts store. its not worth getting a used one for that much
  8. dgg54u
    dgg54u Member
    New Orleans area
    clutch fork
    thanks!, I'll check it out
