Third member swap
Discussion in 'Parts Interchange' started by joerockne, Apr 9, 2022.
  1. joerockne
    joerockne Member
    Norman, OK
    1972 Grabber Maverick
    If I have a 5 lug rear end for a Maverick, can I pull the third member and swap in another 8" one out of a 60s Mustang ?
  2. dyent
    dyent Member
    vancouver bc
    Yes..........
    David
  3. Krazy Comet
    Agreed...
    AFAIK all used 28 spline axles & 1310 U joints. Early cases are not as strong as late '60s up.
    The 9" can use different axle or U joint sizes that prevents a direct swap.
    Ronald Hopkins likes this.
  4. joerockne
    joerockne Member
    Norman, OK
    Another question. I bought a 75 parts car today. A 4 door. It had 5 lug drums. Can I just take those and slide them on the 72 car that has 4 lug spindles? Its probably temporary until I hustle the disc brakes.
  5. Craig Selvey
    No you can't. If only it was that simple. :)
    joerockne likes this.
  6. joerockne
    joerockne Member
    Norman, OK
    OK so I will have to replace that whole spindle ? If that is the case I probably put those Mustang discs on it my buddy has.
  7. Krazy Comet
    As far as front spindles for drum brakes, the ones used for four lug are same as five...
