this is what I got!
Discussion in 'Technical' started by mitch christens, Jan 27, 2009.
  1. mitch christens
    mitch christens Member
    Marion,iowa
    75 maverick, 2006 jaguar x type, 2004 ford f-150 super cab,
    I have a 50 oz crank in a 1980 block. a cam,lifters,pushrods out of a 28 oz engine, distrib. from 28oz water pump of 50oz. Will this engine run with those components?
  2. Bryant
    yes it will
  3. mitch christens
    Marion,iowa
    Of course as along as I use a 500oz flywheel it should bolt to a c-4 I-6 250 tranny. Yes?
  4. Bryant
    thats right. get a 50oz flex plate for a c4 trans. they were never offered from the factory but are aviable from the afermarket
  5. Mavman72
    Make sure you have a 50 OZ harmonic balancer as well...not a 28 OZ.
  6. mitch christens
    Marion,iowa
    Mavman, the balancer bolt on was a success! I was fortunate to have both a 28oz and a 50 oz balancer here so I was able to know for sure I got the 50 on. I do have both flex plates but that bridge will get crossed after the front end is good. just need to solve pulley probs. Thanks!
  7. baddad457
    Actually they were, but only in the 164 tooth flexplates.
