throttle cable?
Discussion in 'Technical' started by HOMERMAV, Nov 1, 2009.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    my throttle cable is not working right it sticks when i floor it and im sure its because it has not been used in 35 years.can i lube it up i tried from the engine compartment but still the same sticking or does any one know where i can get a new one or good used one.
    thanks john
  2. JHodges
    JHodges thumper
    Dora Alabama
    you could probaly get a used one from someone on the board
  3. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Soak it good with PB Blaster, let it sit a while, then soak it again. Put a stiff return spring on, and work it a few times and it should loosen up. If not, Lokar makes a nice but expensive aftermarket cable, or Mean Maverick or Craig Selvey might have a used factory cable.
  4. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    thanks guys i think i will try the pb blaster.it does work a little but when i get to a certain point it sticks.so i will pull it out and soak it.or see if one of the guys on here have one.
    john
  5. bmcdaniel
    Once upon a time mine was sticking because the bracket that the gas pedal pivots on was worn.
  6. perch
    perch Member
    paragould ark
    1973 comet gt
    throttle cable
    if you need one i think i have one in my attic of goody's. if you need it just oay for the shiiping. l i live in ne ark
  7. Craig Selvey
    Look to see if your cable is starting to fray on the inside of the car.
  8. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Also a throttle cabe out of a carburated 5.0 Mustang is nearly identical and will bolt right in.
