throwing belts and need help????
Discussion in 'Technical' started by 73'goose, Apr 8, 2007.
  1. 73'goose
    73'goose 1/4 mile junkie
    Bay Area, CA
    1973 Maverick
    My 73' maverick is well on it's way to being a 12 second car, but whenever we get the car up and over 5500 we are tossing the alternator belt every time. W e had one friend suggest a deep grove alternator for a hopeful cheaper fix. Does anyone else have knowledge on a deep grove alternator or another way i can get rid of my problem????
  2. 73'goose
    Bay Area, CA
    1973 Maverick
  3. mean_maverick
    why not try a serpentine belt setup? that should fix your problem.....
  4. don graham
    make sure everything is lined up and there's no flex in the mounting system. use a good belt and make sure it's tight. i run an alternator with belt to 7200 with no belt problems.:)
  5. 73'goose
    Bay Area, CA
    1973 Maverick
    that is a good idea but we are trying to keep the cost to a minimum
  6. 74MAV
    74MAV Gearhead
    St. Louis MO
    74 Maverick
    Make sure alignment is good, belt is tight, and that belt is not too worn. A newer belt can have a deeper V that fits better than a older belt. I have found a quality brand often fits better than a cheaper off brand.
  7. igo1090
    igo1090 Member
    catonsville, md
    my son's serp setup cost $20 at the junkyard. or check the alignments on all pulleys, & think about a retainer fixture on the long side of the belt.
  8. 73'goose
    Bay Area, CA
    1973 Maverick
    we have already adjusted the alignment making sure it is straight. i will have to look into the serpentine system a little further maybe that could work.
  9. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Invest in a new belt.....one with "GATOR GRIP". It grips better on a tight radius(y)
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Have you considered that you may have:
    Bad alternator bearing
    Bad WP bearing
    Warped pulley
    Maybe the fan or other component is out of balance, worn out, or just plain being worked beyond it's abilities.
    Whenever I have had this issue, it came down to something just plain too worn or too old for the stresses, or poor mounting.
    Any of these make vibration that quickly intensifies as the RPMs go up.
    Then bye-bye belt.
    It will happen to serp systems too. Been there.
    Dave
  11. BadMav7086
    BadMav7086 Member
    Tucson, AZ
    1970 Maverick drag car
    get rid of the alternator:D
  12. hotrod-daddy
    hotrod-daddy Member
    Go to NAPA and get a "Gator Grip" belt or a shorter one to run waterpump only
  13. Mavaholic
    Put a straight edge on the pulleys and make sure they are lined up. I used an after-market balancer on mine and the bottom pulley was was about 5/16" off. Had to have a spacer machined to bring it out.
  14. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
  15. scooper77515
    Like mavaholic said, you got to get that thing lined up straight, use some washers or spacers or something to get it to line up.
    I had mine doing the same thing (except, not a 12 second car:D ) and found that I was off by just 1/8" or so. At that time, I bought a deep socket and cut it to fit...
