ticking noise
Discussion in 'Technical' started by busyb187, Jun 4, 2011.
  1. busyb187
    busyb187 Member
    california
    1971 ford maverick v8
    hey everyone. i just replaced my muffler and now i started hearing a ticking noise on the engine. i cant really tell where its coming from but i know its in the engine. any ideas???
  2. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Could be an exhaust leak.
  3. kyle1972
    kyle1972 Member
    Modesto California
    1972 4 door Maverick 250 I6
    could be exhaust leak by exhaust manifold
  4. maverick75
    How did you replace the muffler, bolt off or cut off?
    In the past when I've used a saw saw to cut off a muffler the vibrations have cracked the donut gasket on the manifold.
    Which causes an exhaust leak.
    I'd check that out.
  5. baddad457
    X 2 :Handshake Remove the air cleaner and with the motor running at a high idle, pour a little automatic trans fluid into the carb throats, this'll produce smoke in the exhaust you can see and should come out where the leak is.
