Tire question....
Discussion in 'General Maverick/Comet' started by DarthMaverick, Jun 10, 2004.
  1. DarthMaverick
    DarthMaverick The Yang of Mavericks
    Bakersfield
    1976 2 door Maverick
    Can I put 15x10 in. rims in the back with a 4.5 backspace?
    I want 275/50/15's. Tell me what you think.
  2. Mavaholic
    I think it will rub, definately on the inside and most likely on the outside too.
  3. igo1090
    igo1090 Member
    catonsville, md
    more like 3 inch bs, maybe.
  4. DarthMaverick
    Bakersfield
    Thanks...
    Well. I'm not sure. I see some other Maverick guys/gals running tires with those specs. They seem to work fine. I was wondering if anybody does run them what are the downsides. I think they would rub but not sure.
  5. courier11sec
    courier11sec Member
    Tucson, AZ
    I haven't seen 10 inch rims on a maverick without rubbing problems.
    That tire size would work on an 8" wheel if it's centered (4" backspace), but it's tight.
    For the record, I run 275/60r15 on Cragars with 4" backspace and have minimal clearance issues, but I did get a hammer and saw involved for a few things on the inside.
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I have not seen a 10" wheel on a a mav without modifications. Either way you look at it, the tire will end up rubbing the leaf spring and the wheel opening. 3" backspacing would get it away from the leafspring but you would have to raise the rearend of the car to get the tires to clear the wheel opening. Seems the easiest to work with rear wheel width is 8".
    Dan
  7. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I have a pair of 295/50R/15 on the back of my '71..but I'm only using an 8"rim with a 4" offset. Everything fits fine and with no rubbing.
  8. fordman
    fordman Member
    lufkin texas
    1972 maverick
    i run a 28 10.5 MT slick 5" back space 8" rim on a 9 "
  9. Maverick Man
    California
    if you want the car to look right they will rub.
    if you jack the car up with air shocks and go for that lovely 70s retro look and have the wheels & tires stick out of the fenders.. yeah you could get them on. but then again do you really want you car to look like that.. Just my 1 cent.
  10. courier11sec
    courier11sec Member
    Tucson, AZ
    Hey! Don't encourage air shocks Derrick! :D
    If you want to raise the rear, use re-arched or four leaf springs.
    Jacking up the rear of the car will hurt weight tranfer, cornering, and comfort.
    In my opinion, you should get with a really good tire and wheel person and stuff as much tire as you can in the stock wheel opening and grab a set of slapper bars or some cal tracks. I have no personal experience with cal tracks but some pretty sharp folks on this board say they work great.
    Put up some pics when you can and good luck!
    :clap:
  11. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    A 15x9" rim w/ 4.25" backspacing will work.....
  12. DarthMaverick
    Bakersfield
    All right. let's see if I figured it out....
    Ixnay on the 10" in rims. Unless I want to modify the backend some how. So I will go for 8" rims with 4" backspacing. 295's???. I was under the impression you had to run a 10" rim with that big of a wheel. I'll go with 275's on an 8 in' rim. If it rubs under hard jounce that is okay. I would like to put cal-trac bars on it. Plus a LSD in the back with 3.55 or 4.11's. I think it would come off the line faster than any import.
  13. Scotty P
    Scotty P Member
    santa rosa, ca
    I am also running 275-60-15 on a 8.5: rim woth 4 7/8 bs, tight fit but the fit INSIDE the wheels. I would like to see pics of your Grabber, I can't imagine how good they looked tucked inside.. Ray, you and I have WAY too much oin common on our rides!! Scotty P
  14. auburn
    auburn Member
    Waterloo, Iowa
    70 Maverick
  15. courier11sec
    courier11sec Member
    Tucson, AZ
    hehehe you're right about that Scotty.
    wouldn't it be cool if we ended up at the same dragstrip one day?
    We could see how the twins do!
