tire size
Discussion in 'Technical' started by stuart, Mar 8, 2004.
  1. stuart
    stuart Member
    georgia
    maverick
    I recently put new tires on my 1970 maverick (200 6cyl with a/c). The man at the tire store told me that my 13" wheels were not the original rims for my car. He told me that I needed to have 14" wheels or it would be unsafe to drive. He said that someone along the way must have put some wheels off of a Pinto on my maverick. Can anyone shed some light on this for me?
    Thanks,
    Stuart
  2. greasemonkey82
    greasemonkey82 Member
    colorado springs
    73 maverick grabber
    I own a 73 maverick with 302, and I was told that my tires should be 14 inch rims with 195 75 r14's. I'm not sure if its the same for your car but maybe this info will help anyway.
  3. Scotty P
    Scotty P Member
    santa rosa, ca
    Stuart
    Called my father who bought my car new, 13" were the size.. Scotty P
  4. Craig Selvey
    1970 Mavericks came standard with 13" tires. 14" was an option.
    Pinto wheels won't fit a Maverick....wrong bolt pattern.
  5. Jason M
    Jason M Hibernatin for the Winter
    Wingham, Ontario
    1976 Ford Maverick
    you can put almost any size tire and rim on a car without your car becoming unsafe... alot of people on here have 15" rims or larger
  6. don graham
    as long as all the tires are the same size it shouldn't matter. plus you're not supposed to mix radial and bias tires.:)
  7. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    aight forget it just go with 20's
