Tires
Discussion in 'General Maverick/Comet' started by aguerra186, Mar 2, 2014.
  1. aguerra186
    aguerra186 Member
    San Antonio, TX
    Ford Maverick
    would 215/70/r14 fit my maverick without any problems?? im about to buy a set of new ones
  2. Paul Masson
    1971 Grabber
    Yes, I had them on my 77 4dr with the Factory Styled Steel Wheels.
  3. Craig Selvey
    Just about a perfect stock tire size on a Maverick.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    What wheels are you running? While the tire is not too big for the car, it is too wide for the stock 4-1/2" wheels, so hopefully you are running wheels that are 6 inches wide.
  5. Rapture
    Rapture Member
    Crystal River, Florida
    1977 Ford Maverick (74, 74 Grabber, 73 Shells)
    what about 7 inch wide on 14? would 215 be a good size or even go up to 225? im going to be buying some original steel rally rims soon and want to make sure i get a size that would look good on it.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Anywhere from 6 inch to 7 inch is wide enough for those tires. A 225/70 will be too tall. You'll need a 60-series if you want to run a 225.
  7. Rapture
    Rapture Member
    hmm yeah then ill have to go with the 215/70/14 then. bf goodrich are the only ones im seeing online who make 225 60s 14 and those are more money than i can scrape together at the moment, thanks for the help :tiphat:
  8. captainmack
    captainmack Quad Door
    I run 205 75 14 ... 26.11 tall, 8.07 wide
    the 215 70 14 are 25.85 tall, and 8.46 wide.
    225 70 14 is width 8.86, 26.40 tall.. the height is cool the width will kill ya
    Mine are as tall as you can get and they are plenty wide for stock appearance. I cant hardly break them loose whilst cornering.
    There is a 215 75 14 but they are trailer wheels (ST) not allowed for passenger cars(P). Side wall flex is my nemesis... I just bought today Uniroyal Tigerpaw AWP II. I'm real excited to try them... from tirebuyer.com Been runnin Hercules MR IV.. been a good tire and was cheap. Blew the side wall out at 50 yesterday in the tunnel under the LAX runway.
    I like the stock look of hubcaps but wish I had 15" or 17" tires to get less sidewall flex..
    I have steel Granada disc steelies that are 1/2 inch wider than the stock mav comet steelies, and the sidewall doesnt pooch out like it used to. if you put those 70's on a stock wheel they are gonna look all balloon-ey. and check with the tire manufacturer for the rim size range acceptable.
