To vinyl or not to vinyl
Discussion in 'General Maverick/Comet' started by Melvis, Oct 17, 2014.
  1. Melvis
    Melvis Member
    Milford, IL
    73 Chevy BelAir
    So my son likes the look of a vinyl roof, but I don't know. This will be his daily driver and will be parked outside for the next several years. I am concerned with the vinyl doing what vinyl does in the sun over a long period of time. I don't want to restore this car only to have issues with vinyl.
  2. Rasit
    Rasit Member
    SE Pennsylvania
    Valid concerns.
  3. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I had problems with my vinyl. Had major rust in the roof and replace 2 section of the roof above the front window and rear. Big holes. So I had it repainted white same color has the vinyl.
    Vinyl does look good if you take care of it. My car is a daily and it's parked outside.
  4. 71gold
    if you prep the roof proper before install you should have years of service from the top....it's his car...:huh:
  5. Paul Masson
    1971 Grabber
    I am replacing my vinyl top on my Grabber. It did show signs of rust along the front edge above the windshield, but like Frank says, if you prep it right, rust shouldn't be an issue. I am hoping to use POR-15, but have yet to get my samples to my vinyl-top guy for some peel-tests.
    What style of top is he considering: Halo, Full, or 3/4?? They all have unique trim with hard-to-find clips and fasteners. And of course, laying out the holes and welding studs onto the body is a job that would require good, if not exact, measurements.
    I can help with any of the full-top trim locations...
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I hate vinyl tops on cars.
  7. junrai
    junrai Member
    rancho cordova ca
    I have been torn as to put a vinyl top on my white comet only because Im afraid I wont like it and will hate it all the time its on there BUT I do like the idea of a full vinyl top in black
  8. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    When I repaint my maverick I am not going to re install a vinyl top and rear tail vinyl. I am however going to keep the trim and paint the roof a gloss white
  9. 71gold
    do that spray on stuff that peels off...:thumbs2:
  10. mavgrab302
    My latest thought was do a vinyl wrap roof in satin black...
  11. CaptainComet
    With you being in Illinois, this might not be as much of a concern, but down here, the sun is intense enough to fade the vinyl over time. I had at 71 Torino that in 1978 needed to have to top redyed.
  12. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    I would just rip it off and prep/ paint it
    Less to worry about
  13. 71gold
    why would there be a worry if it is prepped and installed correctly? the ones on these cars were on for 30-40 years and were factory (no paint under them).
  14. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    My 74 Grabber had paint under the halo vinyl roof. The vinyl roof was factory installed with all of the pins and was a
    !@#$ to strip off.
  15. mojo
    My friend has a 75 Mav. had the vinyl roof replaced last year. His car is white w/ a green halo top. The car looks real nice the new top. I agree w/ Frank: " If it's prepped and done correctly", should last many more years. When you think abt it, most of these cars only come out occasionally, not like when they were used daily, subject to all kinds of weather. Under these conditions - the top should last forever.
